Radio button lists allow the user to select one item at a time from a series that you configure.
Example
This image is an example of a radio button input in a report:
Settings
To display a series of radio buttons in your report, configure the following settings on the Edit Report Input dialog box:
Setting |
Selection |
Input Variable |
The name you will use as a parameter in the report query. |
Display Name |
Then name that will appear as a label for the input in the report. |
Input Variable Type |
String |
Input Control Type |
RadioButton |
Required |
Optional |
Default Value |
Gui |
Values |
DataSet |
DataSet |
The data set you created for this input |
Value Field |
jobinitfrom |
Label Field |
jobinitfrom |
The following image is an example of the configured settings.
Associated Input Variables
Boolean
Decimal
Integer
String
