Setting the Rules for Using the Oracle Send Command
By default, the software uses the RMAN SEND command to send the parameters from the generated RMAN script.
An RMAN script is created:
  • By the Commvault software based on the options a user selects in the CommCell Console
  • By a user to configure, back up or restore the Oracle data
The RMAN script can have lines that define the media parameters (for example the "allocate channel" or "ENV").
If the lines have more characters than Oracle recommends, use the SEND command.
When you set this additional setting to 'Y", the software uses the RMAN SEND command to send the parameters from the generated RMAN script.
When you set this additional setting to 'N', the software does not use the RMAN SEND command.
For more information on the Oracle SEND command, go to the Oracle documentation website, SEND.
  1. From the CommCell Browser, right-click CommServe node and then click Properties.
  2. In the CommCell Properties dialog box, click the Additional Settings tab and then click Add.
  3. In the Add Additional Settings dialog box, enter the details for the additional setting:
    1. In the Name box, type sUSERMANSENDCMD.
    2. In the Category box, select OracleAgent.
    3. In the Type box, select String.
    4. In the Value box, type Y to have use the Oracle SEND command.
    5. Click OK to close the Additional Settings dialog box.
  4. Click OK to close the Properties dialog box.
