Text boxes allow the user to enter a string of text that will be used to filter report data.
Example
This image is an example of a text box input in a report:
Settings
To display a text box in your report, configure the following settings on the Edit Report Input dialog box:
Setting |
Selection |
Input Variable |
The name you will use as a parameter in the report query. |
Display Name |
Then name that will appear as a label for the input in the report. |
Input Variable Type |
String |
Input Control Type |
TextBox |
Hide Input |
Cleared |
Required |
Optional |
Default Value |
Blank |
The following image is an example of the configured settings.
Associated Input Variables
Boolean
Decimal
Integer
String
