eDiscovery and Compliance: System Requirements and Hardware Specifications
Verify that your environment meets the system requirements for Compliance and eDiscovery.
Commvault Packages
To use Data Insights for Compliance and eDiscovery, install the following packages on a computer.
  • Index Store
  • Exchange Mailbox Agent
Operating System
The computer that you install the required Commvault packages on must use one of the following operating systems.
Windows
  • Microsoft Windows Server 2022 Editions
  • Microsoft Windows Server 2019 Editions
  • Microsoft Windows Server 2016 x64 Editions
  • Microsoft Windows Server 2012 R2 x64 Editions
  • Microsoft Windows Server 2012 x64 Edition
For additional system requirements for the Exchange Mailbox Agent, see Exchange Mailbox Agent: System Requirements.
File Data
Content indexing file system data from backups
Large
Medium
Small
Source data size per node
Based on the following assumptions:
  • The average file size is 1 MB
  • 50% of documents are eligible for content indexing
  • There is only one version of the file
160 TB
80 TB
40 TB
Objects per node (estimated)
30 million
15 million
7.5 million
CPU or vCPU
32 cores
16 cores
8 cores
RAM
64 GB
32 GB
16 GB
Disk space
12 TB
6 TB
3 TB
To get higher scalability for content indexing files from backups, you can turn off the generate previews option on the Search Engine node. When generate previews is off, each search node can accommodate approximately twice the number of objects per node. For example, in a large enterprise, this would be approximately 40 TB of source data (about 60 million objects), and the required disk space is 15% of source data (up to 6 TB).
Email Messages
Component
Large
Medium
Small
Source application size
25 TB
15 TB
5 TB
Objects per node (an estimate based on an average message size of 100 KB. Messages with attachments are considered a single object)
250 million
150 million
50 million
Number of mailboxes (based on an average mailbox size of 5 GB, and an average of 50,000 messages per mailbox)
5000
2000
400
CPU
16 cores
16 cores
8 cores
RAM
64 GB
32 GB
16 GB
Index disk space
(SSD class disk recommended)
10 TB
6 TB
2 TB
