Obtaining the Engine ID for the CommServe Host
If your SNMP Version 3 (SNMPv3) receiver software requires the sender engine ID, you can configure the EvMgrS.log to return the engine ID for the CommServe host.
  1. To the CommServe computer, add the bLogSNMPEngineId additional setting as shown in the following table.
    For instructions on adding additional settings from the CommCell Console, see Adding or Modifying Additional Settings from the CommCell Console.
    Property
    Value
    Name
    bLogSNMPEngineId
    Category
    CommServe
    Type
    BOOLEAN
    Value
    true
  2. For the EvMgrS.log, set the debug level to 5.
    For instructions about setting log file debug levels, see Configuring Log File Settings in the CommCell Console.
  3. Set up an SNMP notification, and trigger the alert.
    For information about SNMP notifications, see Setting Up SNMP Trap Alert Notifications.
  4. Open the EvMgrS.log to view the engine ID.
    Example
    1048 1c24 10/04 16:14:16 ### CvXSnmp_IssueV3Trap() - Context Engine Id: 80 00 1f 88 80 70 43 00 00 ff 82 d4 59 00 00 00 00
    1048 1c24 10/04 16:14:16 ### CvXSnmp_IssueV3Trap() - Security Engine Id: 80 00 1f 88 80 70 43 00 00 ff 82 d4 59 00 00 00 00
  5. Use the engine ID to configure your SNMPv3 receiver software as instructed by the software provider.
