System Requirements for the HPE EVA Storage Array
Before you configure your storage array, verify that your system meets the following requirements.
Licenses
Install the following licenses.
Array
Snapshot Type
License
HPE EVA
EVA Business Copy Snapshot
HPE Business Copy EVA
EVA Business Copy Clone
Version and Firmware
Ensure that you are using compatible versions and firmware.
Array
HPE EVA
EVA
HPE EVA 10.3
Protocols
Ensure that at least one of the following protocols is available:
Array
Protocol
HPE EVA
Fibre Channel
iSCSI
Software
Install the following software components:
Array
Required Software
HPE EVA
HPE SMI-S EVA on the server
Command View Version 9.3 or 9.1
Ports
For snap-based operations, open port 5989 for HTTPS and port 5988 for HTTP between the CommServe computer or MediaAgent and the storage array.
