XML Parameters for Backups and Restores
The following table describes the supported Sybase backup and restore parameters.
Parameter
Parameter Values
taskFlags/disabled
The option to disable the schedule.
Valid values are:
  • true
  • false
policyType
The storage policy type.
A valid value is DATA_PROTECTION.
innitiatedFrom
Where the restore is initialed from (for example CommCell Console, or command line).
A valid value is COMMANDLINE.
backupsetName
The name of the backup set.
clientName
The name of the client computer, as displayed in the CommCell Console where the instance is located.
appName
The name of the application, 'Sybase'.
instanceName
The name of the Sybase instance.
subTaskType
The sub task.
Valid values are:
  • BACKUP
  • RESTORE
operationType
The type of task.
Valid values are:
  • BACKUP
  • RESTORE
backupLevel
The type of backup to perform
Note: You can only perform a differential backup on a Sybase server that runs Sybase 15.7 SP100 or later.
Valid values are:
  • FULL
  • INCREMENTAL
  • DIFFERENTIAL
createNewIndex
The option to create a new index.
Valid values are
true
false
followMountPoints
The option to follow the mount points.
Valid values are
true
false
useCatalogServer
The option to use a catalog server.
Valid values are
true
false
enforceTransactionLogUsage
The option to use the transaction logs for granular restarts.
Valid values are
true
false
skipConsistencyCheck
The option to skip the consistency check.
Valid values are
true
false
runIncrementalBackup
The option to run an incremental backup.
Valid values are
true
false
incLevel
The incremental level.
Valid values are:
  • NONE, for no incremental level
  • BEFORE_SYNTH, for before synthetic full
  • AFTER_SYNTH, for after synthetic full
doNotTruncateLog
The option to not truncate the logs.
Valid values are
true
false
sybaseSkipFullafterLogBkp
The option to skip a full backup for new Sybase databases after a log backup.
Valid values are
true
false
commCellId
The CommCell ID of the CommServe.
A valid value is 2.
timeRange
The following values can be used to define the given parameter:
  • Latest
  • Point in time
  • TimeRange
noImage
The option to include deleted items in the browse.
Valid values are:
  • true
  • false
useExactIndex
The option to use the index associated with the data protection operation performed at a specific time or the latest index.
Valid values are:
  • true
  • false
copyPrecedence
The backup copy precedence.
copyPrecedenceApplicable
Valid values are:
  • true
  • false
drive
The name of the drive in the pool that performs the restore.
drivePool
The name of the drive pool that performs the restore. Use this option to restore by using a specific drive.
library
The name of the library that performs the restore. Use this option to restore by using a specific library.
mediaAgent
The name of the MediaAgent that performs the restore.
library
The library to use for the restore.
mediaAgent
The MediaAgent to use for the restore
destClient/clientName
The destination client name.
destClient/instanceName
The destination instance name
sybaseRecoverType
The recovery type.
A valid value is STATE_RECOVER.
pointInTime/timeValue
The date and time to use for a point-in-time recovery to a specific log
Sample values:
  • 2015-12-11 09:22:32
  • 2015-01-01 17:22:32
pointofTime
The option to perform a point-in-time restore.
Valid values are:
  • true
  • false
overWrite
Valid values are:
  • true
  • false
fromTime
The time to restore from.
Sample values:
refTime
destinationServer/name
The name of the server that is the restore destination.
instanceRestore
The option to restore the instance.
Valid values are:
  • true
  • false
sybaseDatabase/databaseId/name
The Sybase database name.
sybaseDatabase/creationTime
The time that the Sybase database was created.
sybaseDatabase/subclient
The subclient that is associated with the Sybase database.
sybaseDatabase/devices
The devices that are associated with the Sybase database.
A colon (:) separated field that has 8 fields
  1. Source subclient Id: This is an internal field for subclient Id. You must pass this as 0 for the qcommand.
  2. Source dbId: database Id of the Sybase dataserver. You can get this value from the Sybase sysdatabases table.
  3. Source device Id: device id of the source device. You can pass this as 0 for the qcommand.
  4. Source device Name: source Sybase device name. You can get this value from the Sybase sysdatabases table.
  5. Renamed device Name: Device name on the destination (new name for the Sybase device).
  6. Renamed device Path: Destination server Device Path.
  7. Size of the device in bytes: If you already create the device, use 0 for the value.
  8. Renamed Database Name: New name for the database on destination server. The restore is performed on this database. If the database is already created, the created size must match the source.
databaseChain
A colon (:) separated field that has 4 fields.
  1. Source subclient Id: This is an internal field for subclient Id and need to be passed as 0 in qcommand.
  3. Source database: The name of the source database.
  4. 0
renameDatabases
The option to rename the database
Valid values are:
  • true
  • false
restoreOptions
The option to restore the database
Valid values are:
  • true
  • false
restoreType
The type of restore to perform.
Valid values are:
  • POINT_IN_TIME
  • STEP_BY_STEP
onePassRestore
The option to perform a OnePass restore.
Valid values are:
  • false
sybaseCreateDevices
The option to create the Sybase devices.
Valid values are:
  • true
  • false
startInSuspendedState
The option to start the database in a suspended state.
Valid values are:
  • true
  • false
priority
The job priority
jobDescription
The job description.
