Create a Power Platform Plan for Power BI
Create a Power Platform plan for the Power BI application to define how Power BI data is backed up, including the schedule and retention settings.
Create a Plan
  1. From the Command Center navigation pane, go to Manage > Plans.
    The Plans page appears.
  2. In the upper-right area of the page, click Create plan, and then select Power Platform.
    The Create Plan tab appears.
  3. In the Plan name box, enter a name for the plan.
  4. Under Retention, specify whether to retain the data indefinitely or for a specified number of days.
  5. Click Submit.
