You can enable power management for a cloud MediaAgent. You can opt to use the power management settings of the server group that the MediaAgent is associated with or configure different settings.
Verify that the cloud MediaAgent uses a fully qualified domain name (FQDN) or a static publicly accessible IP address.
Select the Auto-start services when OS starts checkbox for the cloud MediaAgent.
For more information, see Viewing Services.
For the cloud MediaAgent in a Linux environment, verify that the dmidecode tool is available.
For more information about the tool, see dmidecode.
From the Command Center navigation pane, go to Manage > Infrastructure.
The Infrastructure page appears.
Click the MediaAgent tile.
The MediaAgent page appears.
Click the MediaAgent.
In the Power management area, click Edit.
The Edit power management dialog box appears.
Select one of the following options:
Use server group settings: This is the default option. Select this option to use the power management settings of the server group that the MediaAgent is associated with.
Use MediaAgent settings: Select this option to configure different settings for the MediaAgent.
If you selected the Use MediaAgent settings option, complete the following steps:
Select Enable power management.
Select the Cloud account.
Click Save.
