Required outbound connections for Air Gap Protect storage
To communicate with your storage, Air Gap Protect requires that certain endpoints (URLs) be opened.
Considerations
  • Replace [region] with the region the MediaAgent is in.
  • For Azure Blob Storage, after the storage account is created, replace * in *.blob.core.windows.net with the name of the storage account.
  • If your environment restricts outbound traffic by IP allowlists, verify the published cloud IP ranges for your provider:
Air Gap Protect in Amazon S3
Source Destination TCP/UDP Port
Customer workload network s3.[region].amazonaws.com TCP 443
Customer workload network s3.us-gov-east-1.amazonaws.com TCP 443
Customer workload network s3.us-gov-west-1.amazonaws.com TCP 443
Air Gap Protect in Azure Blob Storage
Azure global regions
Customer workload network *.blob.core.windows.net TCP 443
Customer workload network https://login.microsoftonline.com TCP 443
Azure Government regions
Customer workload network *.blob.core.usgovcloudapi.net TCP 443
Customer workload network https://login.microsoftonline.us TCP 443
Air Gap Protect in Google Cloud Storage
Customer workload network storage.googleapis.com TCP 443
Customer workload network https://www.googleapis.com TCP 443
Air Gap Protect in OCI Object Storage
Customer workload network objectstorage.[region].oraclecloud.com TCP 443
Customer workload network identity.[region].oraclecloud.com TCP 443
Control plane https://login.microsoftonline.com TCP 443
Control plane https://api.mcss.metallic.io (IP address: 40.75.17.108) TCP 443
Control plane https://metallic.io TCP 443
Control plane https://www.commvault.com TCP 443
