Setting up the Network for HyperScale Edge
Setting up the network is the first phase in deploying the HyperScale Edge nodes. All the network related information is required during this phase.
Make sure to determine your network topology before setting up the network in your HyperScale Edge node.
Network can be setup using one of the following configuration methods depending on the network topology for your environment:
Use one of the following configuration methods depending on the network topology for your environment:
