Setting Up a Network Gateway Connection Using a Predefined Network Topology
If you are setting up group-to-group network connectivity through a network gateway, consider using a network topology instance.
With the topology for a network gateway connection, you can configure multiple client computers to provide a single logical network gateway function.
