Requirements:
The source and target DB2 DPF databases must have the same number of nodes.
Commvault must be installed on all target DB2 DPF machines and there must be a configured pseudo client in the CommServe.
In the case of a partial restore, the DB2 DPF NODE0 tables space "SYSCATSPACE" must be part of a partial redirect restore.
Use the following steps to perform a cross-database / cross instance / cross machine restore.
For cross database restores, run all DB2 commands on the target machines for the DB2 instances/DB2 database.
For DB2 DPF
At the Command Prompt, type the restore command.
For non-automatic storage database:
export DB2NODE=n db2 terminate db2 restore db Source DB2 Database Name \ load 'software install path/Base/libDb2Sbt.so' \ open n sessions \ 'options "\ CvDpfClientName=Target MultiNode Pseudo Client Name,\ CvDpfControlHostName=Target Client Name,\ CvSrcClientName=Source MultiNode Pseudo Client Name,\ CvSrcDB2InstanceName=Source DB2 Database Name,\ CvSrcDbName=Source DB2 Database Name, \ CvInstanceName=Instance001"' \ taken at Source DB2 Database NODE<n> backup image date \ to 'Target DB2 Database Path' \ into Target DB2 Database Name \ without promptingFor automatic storage database:
export DB2NODE=n db2 terminate db2 restore db Source DB2 Database Name \ load 'software install path/Base/libDb2Sbt.so' \ open n sessions \ 'options "\ CvDpfClientName=Target MultiNode Pseudo Client Name,\ CvDpfControlHostName=Target Client Name,\ CvSrcClientName=Source MultiNode Pseudo Client Name,\ CvSrcDB2InstanceName=Source DB2 Database Name, \ CvSrcDbName=Source DB2 Database Name,\ CvInstanceName=Instance001"' \ taken at Source DB2 Database NODE<n> backup image date \ ON 'Target DB2 Database Path' \ DBPATH ON 'Target DB2 Database Path' \ into Target DB2 Database Name \ without promptingWhere:
n = DB2 Node Number
CvDpfClientName = Target MultiNode pseudo client name in Commvault CommServe
CvDpfControlHostName = Target DB2 client name
CvSrcClientName = Source MultiNode Pseudo client name in Commvault CommServe
CvSrcDB2InstanceName = Source DB2 instance name
CvSrcDbName = Source DB2 database name
CVInstanceName= Commvault instance name
taken at = Source DB2 Database NODE<n> backup image date
ON = Target DB2 Database storage path
DBPATH ON = Target DB2 database directories path
Into = Target DB2 database name
Re-update the db2 database configuration parameters LOGARCHOPT1/VENDOROPT since they are overwritten by source database after restore. Set the CvSrcDbName option for the LOGARCHOPT1 parameter to the source database name.
Roll forward the DB2 database.
export DB2NODE=0 db2 terminate db2 update db cfg for database name DBPARTITIONNUM (n) using LOGARCHOPT1 "'\ CvDpfClientName=Target_ Db2MultiNode_PesudeoClientName,\ CvDpfControlHostName=Target_DB2_Client_Machine_Name,\ CvSrcClientName=Source_ Db2MultiNode_PesudeoClientName,\ CvSrcDB2InstanceName=Source_DB2DPF_Instance_Name,\ CvSrcDbName=Source_DB2_Database_Name,\ CvInstanceName=Instance001"' db2 update db cfg for database name DBPARTITIONNUM (n) using VENDOROPT "'\ CvDpfClientName=Target_ Db2MultiNode_PesudeoClientName,\ CvDpfControlHostName=Target_DB2_Client_Machine_Name,\ CvSrcClientName=Source_Db2MultiNode_PesudeoClientName,\ CvSrcDB2InstanceName=Source_DB2DPF_Instance_Name,\ CvSrcDbName=Source_DB2_Database_Name,\ CvInstanceName=Instance001"' db2 rollforward db new_db to end of logs and stop
For DB2 pureScale
db2 restore db Source DB2 Database Name \ load 'software install path/Base/libDb2Sbt.so' \ open n sessions \ 'options "\ CvDpfClientName=Target MultiNode Pseudo Client Name,\ CvDpfControlHostName=Target Client Name,\ CvSrcClientName=Source MultiNode Pseudo Client Name,\ CvSrcDB2InstanceName=Source DB2 Instance Name,\ CvSrcDbName=Source DB2 Database Name,\ CvInstanceName=Instance001"' \ taken at Source DB2 Database backup image date \ ON 'Target DB2 Database Path' \ DBPATH ON 'Target DB2 Database Path' \ into Target DB2 Database Name \ without promptingWhere:
n = DB2 Node Number
CvDpfClientName = Target MultiNode Pseudo Client Name in Commvault CommServe
CvDpfControlHostName = Target DB2 Client Name
CvSrcClientName = Source MultiNode Pseudo Client Name in Commvault CommServe
CvSrcDbName = Source DB2 Database Name
CVInstanceName = Commvault instance name
ON = Target DB2 Database Storage Path
DBPATH ON = Target DB2 Database Directories Path
Into = Target DB2 Database Name
db2 update db cfg for database name using LOGARCHOPT1 "'\ CvDpfClientName=Target_ Db2MultiNode_PesudeoClientName,\ CvSrcClientName=Source_Db2MultiNode_PesudeoClientName,\ CvSrcDB2InstanceName=Source_DB2DPF_Instance_Name,\ CvSrcDbName=Source_DB2_Database_Name,\ CvInstanceName=Instance001"' db2 update db cfg for database name using VENDOROPT "'\ CvDpfClientName=Target_ Db2MultiNode_PesudeoClientName,\ CvSrcClientName=Source_Db2MultiNode_PesudeoClientName,\ CvSrcDB2InstanceName=Source_DB2DPF_Instance_Name,\ CvSrcDbName=Source_DB2_Database_Name,\ CvInstanceName=Instance001"' -
