Destination Volume Pool Properties (General)
Use this tab to add or edit the name of the destination pool.
Name
Displays the name of the destination volume pool. You can use this space to enter or modify the name of the destination volume pool.
Use for SnapVault Only
If selected, this Destination Volume Pool can only be used by SnapVault.
Use for SnapMirror Only
If selected, this Destination Volume Pool can only be used by SnapMirror.
Total Volumes
Displays the number of volumes that are currently in the destination volume pool.
Available Volumes
Displays the number of available volumes that are currently in the destination volume pool.
