Use this dialog box to enter information about the Greenplum pseudo-client or instance.
The Greenplum admin uses the information that you provide on this screen to connect to the Greenplum master server.
Client Name
The name of the Greenplum pseudo-client that identifies the Greenplum Database system.
Instance Name
The name that identifies the Greenplum installation.
Master Node
The master host name.
Master Data Directory
The directory on the master host that contains the Greenplum system catalog.
Greenplum Home Directory
The directory on the master host that contains the Greenplum software.
Greenplum Admin
The Greenplum admin user. This is gpadmin by default.
Default Database Name
The Greenplum database that you want to back up. This database must exist in the Greenplum instance. This can be an actual database, or you can use the "template1" database that Greenplum installs by default.
Port Number
The master host port number.
