You can configure specific networks for your laptop backup jobs. Your backup job will run only when you are connected to the networks you configure.
Before you can add networks, your administrator must enable this feature by creating an automatic schedule with the Manually choose the preferred network option. Contact your administrator for additional details.
In Edge Monitor, click Add Network.
The Add Network dialog box appears.
From the list of networks, click a network, and then click Add.
The network is moved to the box below the list.
