MongoDB Advanced Subclient Properties (Advanced Options) - Online Help
Use this dialog box to specify subclient properties.
Catalog additional file and system attributes
Enable collection of file and system data so that you can create a report with the Build-Your-Own Reports feature or run the File Level Analytics Reports.
Exclude from SLA and Strike Counts
When this option is selected, the subclient is excluded from the SLA (Service Level Agreement) calculation and the Client Strike calculation for the Worldwide Dashboard, CommCell Dashboard, SLA Report, and Client Strike Count Report. When this option is cleared, the subclient is included in these calculations.
Ignore Strikes Before
When selected, allows you to configure the cutoff date for counting strikes. Any strikes that occurred prior to the date you specify will not be counted in the strike calculation for the Worldwide Dashboard, CommCell Dashboard, and Strike Count report.
