Mount Path Properties (Centera Info)
Use this dialog box to view the properties of a Centera disk library.
Properties
ClusterName
The Centera cluster name assigned to the Centera cluster when it was configured.
Space Used
The total amount of space used in the Centera disk library.
Total Space
The total amount of space available in the Centera disk library.
Access Paths
Host Name
The IP address or the hostname of the Centera disk library.
Port
The port number in the Centera cluster used by the system to access the Centera cluster.
