Running the Cataloging Phase for File System IntelliSnap
You can skip the cataloging phase during IntelliSnap backups and run it later during off-peak times as a separate job on the storage policy.
Cataloging runs on the primary copy by default. To reduce the load on the primary file server, you can use a mirror or vault copy. You can select specific snapshots to perform cataloging.
Prerequisites
Configuring a Storage Policy for Cataloging Snapshots
  • You cannot re-catalog a snap backup job.
  • If you want to run cataloging on incremental backups, ensure that there is a full backup present. If only incremental backups are present, you must run cataloging on at least one incremental backup.
  • Data pruning occurs according to the retention criteria in the storage policy though the backups are in picked state.
  1. From the CommCell Browser, expand Policies > Storage Policies.
  2. Right-click the appropriate storage policy, point to All Tasks, and then click Run Snapshot Cataloging.
    You can view the progress of the job in Job Controller window.
Selecting the Jobs Manually for Cataloging
