Use this tab to view the properties of a selected subclient.
Client Name |
The pseudoclient to which the subclient belongs. |
iDataAgent |
The agent to which the subclient belongs. |
Subclient Name |
The subclient. You can enter or modify the subclient. |
UNIX mtime |
Select this option to determine which files are selected for incremental backup by changes in the mtime timestamp. |
UNIX ctime |
Select this option to determine which files are selected for incremental backup by changes in the ctime timestamp. |
Description |
Enter a description of the entity. This description can include information about the entity's content, cautionary notes, and so on. |
Save As Script |
Click to save this operation and the selected options as a script file (in XML format). You can execute the script from the command line interface using the qoperation execute command. When you save an operation as a script, each option in the dialog box has a corresponding XML parameter in the script file. When executing the script, you can modify the value for any of these XML parameters. |
