Subclient Properties (General) - Online Help
Use this tab to view the properties of a selected subclient.
Client Name
The name of the client computer to which this subclient belongs.
iDataAgent
The identity of the Agent to which the subclient belongs.
Subclient Name
The name of this subclient.
You can use this space to enter or modify the name of the subclient.
Enable OnePass
Select this option to enable archiving for the Agent. Once selected a license will be consumed.
Use this field to enter a description about the entity. This description can include information about the entity's content, cautionary notes, etc.
Save As Script
Click to open the Save As Script dialog box, which allows you to save this operation and the selected options as a script file (in XML format). The script can later be run from the Command Line Interface using qoperation execute command.
When you save an operation as a script, each option in the dialog box has a corresponding XML element in the script file. When you run the script, you can modify the value in any of these XML elements.
