Use this tab to view the properties of a selected subclient.
Client Name |
The name of the virtual client to which this subclient belongs. |
iDataAgent |
The identity of the Agent to which this subclient belongs. |
Instance |
The name of the instance to which this subclient belongs. |
Subclient Name |
The name of this subclient. You can use this space to enter or modify the name of the subclient. |
Description |
Use this field to enter a description about the entity. This description can include information about the entity content, cautionary notes, and so on. |
Save As Script |
Click to open the Save As Script dialog, which allows you to save this operation and the selected options as a script file (in XML format). The script can later be executed from the Command Line Interface using qoperation execute command. When you save an operation as a script, each option in the dialog will have a corresponding XML parameter in the script file. When executing the script, you can modify the value for any of these XML parameters as per need. |
