System Requirements for Virtualize Me for Azure and Azure Stack
Verify that your environment meets the system requirements for Virtualize Me for Azure and Azure Stack.
Operating System
Important
Use the most recent version of the operating system that is listed. The Commvault software fully supports the most recent version of an operating system, until the vendor ends support. More recent versions of the Commvault software might not install on operating systems that are not supported by the vendor anymore. For information about the support lifecycle of an operating system, contact the vendor.
Client Computer
Operating system
Processor architecture
Microsoft Windows Server 2022
All Windows-compatible processors are supported
Microsoft Windows Server 2019 (Standard, Datacenter) (64-bit only)
Windows 2016
Microsoft Windows Server 2016 Editions
Nano Servers are not supported. For more information, see Considerations for Microsoft Windows Server 2016.
Microsoft Windows 10
Microsoft Windows Client 10 Editions
Microsoft Windows Client 8.1
For more information, see Considerations for Microsoft Windows Server 2012, 2012 R2, and Windows 8.
Windows 2012
Microsoft Windows Server 2012 Editions
Microsoft Windows Server 2012 R2 Editions
For more information, see Considerations for Microsoft Windows Server 2012, 2012 R2, and Windows 8.x.
Windows 7
Microsoft Windows 7 Editions
Microsoft Windows Server 2008 R2 Editions
Server Core installations are not supported.
Proxy Client Computer
Operating system
Windows 2016
Windows Server 2012
Windows 2012
Clustering
If clustering is supported by the operating system, you can install the software on a cluster. For information about supported cluster types, see Support for Cluster Configuration.
Hard Drive
4K (4096 Bytes per sector) disks are not supported for VirtualizeMe.
Component
Space required
Software
1 GB
Job results folder
To calculate the disk space requirements for the job results directory, see Job Results Directory Disk Space Calculation.
Log folder
500 MB
General Requirements and Support
  • The CommServe computer must not be configured as the proxy computer.
  • You must enable the Remote Desktop Protocol (RDP) on the source computer so that you can access the restored virtual machine.
  • Configure block-level backups for the client computer. For more information, see Configuring a Subclient for Block-Level Backups for the Windows File System Agent.
  • Microsoft Azure Stack does not support Unified Extensible Firmware Interface (UEFI) firmware, so Virtualize Me of source machines in UEFI firmware mode is not supported.
  • On Azure, only Azure Resource Manager deployments are supported.
  • iSCSI volumes are not supported for restores.
DISCLAIMER
