In a SAP HANA system replication setup, if the primary and secondary nodes are located on different regions, you can configure the backups to use the storage policy that has libraries that are local to the region of the current primary (source) node.
For each region, create a dedicated client computer group, and add the SAP HANA clients to the groups in their region. For more information, see Creating a Client Computer Group.
To the client computer group, add the EnableRegionBasedBackups additional setting as shown in the following table.
For instructions about adding an additional setting from the CommCell Console, see Adding an Additional Settings from the CommCell Console.
Property
Value
Name
Category
iDataAgent
Type
Boolean
Value
True
On the Storage device tab for each dedicated client computer group, assign a storage policy that is for the same region.
