By default, third party command line multiple stream backups share a single job in the Job Manager. Use the following steps to disable the single job ID and generate separate job IDs for each stream.
From the CommCell Browser, navigate to Client Computers.
Right-click the <Client> in which you want to add the additional setting, and click Properties.
Click the Advanced button on the Client Properties dialog.
On the Additional Setting tab on the Advanced Client Properties dialog and click the Add button.
In the Name field, enter sSKIPSINGLEJOBID.
In the Location box, select or enter HKEY_LOCAL_MACHINE\Software\CommVault Systems\Galaxy\Instance<xxx>\DB2Agent.
In the Type box, select one of the following:
REG_SZ for Windows clients
Value for Unix clients
In the Value field, type Y.
