Virtual Machine Location for Azure or Azure Stack Hub Computers
On the Virtual Machine Location page, you can make the following selections:
Client
In the Client box specify the name of the Azure or Azure Stack Hub proxy client computer used for the Virtualize Me operation.
Resource Group
Specify the Resource Group for the restored VM.
Storage Account
Select the storage account to be used for all selected virtual machines or disks. For Azure Resource Manager, you can specify any storage account in the same region as the selected resource group.
Size
You can edit the size specification for the restored virtual machine. The size is determined and displayed automatically based on the source computer configuration.
VM Name
Enter name of the virtual machine.
Create Public IP
Select the Create Public IP check box to automatically assign a public IP address to the virtual machine that is created.
A public IP address is necessary to access the newly created virtual machine after the restore operation finishes. If you do not select the Create Public IP check box, then you can assign a public IP address to Azure or Azure Stack Hub virtual machines later after the restore operation finishes using the Azure or Azure Stack Hub portal.
