Creating a Commvault Risk Analysis Project for MS OneDrive for Business
You can create a Commvault Risk Analysis project and add MS OneDrive for Business data sources.
Start the Configuration Wizard
  1. From the Command Center navigation pane, go to Comply > Risk Analysis.
  2. Click Sensitive data governance.
    The Overview page appears.
  3. On the Projects tab, click Add, and then select OneDrive.
  4. The configuration wizard appears.
Project
  1. Click the Projects Add button plus_icon.
    The Add project dialog box appears.
  2. Enter a Name for the project.
  3. For Plan, select a data classification plan. To add a new plan, see Configuring a Data Classification Plan for Commvault Risk Analysis.
  4. Click Save.
  5. Click Next.
OneDrive Apps
  1. Under Server name, select one or more OneDrive servers that you want to include in the project.
  2. Click Next.
Configuration
  1. For Display name, enter a name for the OneDrive data source.
  2. Select a Country name for the data source.
  3. For Users, either select All users, or select from available OneDrive users by performing the following steps:
    Only users that have the status of Included in backup can be selected for the Risk Analysis scan. Users that have the status of Deleted from content or Excluded from backup cannot be selected. For more information, see the following:
    - Excluding a User or a User Group from Backups of a OneDrive for Business App.
    - Deleting a User or a User Group from a OneDrive for Business App.
    1. Select Select and add users.
      A selection panel appears.
    2. Click Add.
      The Select users dialog box appears.
    3. Select one or more OneDrive users, and then click Save.
  4. Click Create.
    The Risk Analysis scan begins for the project.
