Enabling File Indexing for Virtual Machines at the VM Group Level
You can enable file indexing for a hypervisor at the VM group level.
Only MSP admins, and not tenant admins, can enable file indexing for supported hypervisors at the VM group level.
  1. From the Command Center navigation pane, go to Protect > Virtual machines.
    The Overview page appears.
  2. Click the VM groups tab.
  3. On the VM groups tab, click a VM group, and then click the Configuration tab.
  4. In the Options area, move the Index files after backup toggle key to the right.
