You can restore the HBase namespaces and tables to their current location (in place).
From the Command Center navigation pane, go to Protect > Big data.
The Big data page appears.
Click the cluster that has the HBase app added.
The cluster page appears.
Under Hadoop Apps, click HBase.
The app page appears.
Under Subclients, in the row for the subclient, click the action button
, and then click Restore.The Backup content page appears.
Select the namespaces or tables to restore, and then click Restore.
The Restore dialog box appears.
On the In place tab, click OK.
