Restoring Kudu Tables to Their Current Location (In Place)
You can restore Kudu tables to their current location (in place).
  1. From the Command Center navigation pane, go to Protect > Big data.
    The Big data page appears.
  2. Click the cluster that has the Kudu app added.
    The cluster page appears.
  3. Under Hadoop Apps, click Kudu.
    The app page appears.
  4. Under Subclients, in the row for the subclient, click the action button action_button, and then click Restore.
    The Backup content page appears.
  5. Select the tables to restore, and then click Restore.
    The Restore dialog box appears.
  6. On the In place tab, click OK.
