Running a Manual Use Case
You can run a manual use case in Palo Alto Cortex XSOAR.
  1. Open the Automations Browser by clicking the exclamation point button Running a Manual Use Case (1) at the bottom of the Settings page.
  2. Search for your integration name in the search bar.
    Your integration name appears in the Automations Browser.
  3. Click the plus sign button Running a Manual Use Case (2) next to the integration name.
    The use cases for the integration appear in the Automations Browser.
  4. Click Run for the use case you want to run.
    The use case dialog box appears.
  5. In the Using list, add one or more instances, or leave empty to use all instances.
  6. Click Run.
    The Execute in Playground? confirmation appears.
  7. Click Yes, execute in the playground.
The Playground – War Room screen appears, showing messages associated with the use case.
