Setting Up a Two-Way Direct Connection Using a Predefined Network Topology
You can create a network topology instance in which members of either client group can connect to members of the other client group.
  • Verify that the client groups that you want to use in the network topology instance are already defined in the CommCell Console or the Command Center.
  • You must have Administrative Management permissions on the client groups that you plan to use in the network topology instance.
  • Both DMZ servers/infrastructure computers and servers/laptops should be able to open connections to each other on the tunnel port.
  1. From the Command Center navigation pane, go to Manage > Network.
  2. Click Network topologies.
    The Network topologies page appears.
  3. Click Add topology.
    The Add topology dialog box appears.
  4. In the Name field, enter a name for this instance of a two-way direct connection.
  5. For Client type, select Servers.
  6. From the Topology type list, select Two-way.
  7. Click Next.
  8. From the Servers list, select the server group that will initiate connections with members of the infrastructure computers group.
  9. Optional: Click the advanced toggle to edit the following options:
    • Tunnel port. Set this to Default (8403), or enter another port number.
    • Keep-alive interval. The interval (in seconds) for sending keep-alive packets, to maintain the session if backup traffic has an extended pause. Set this to 180 (default), or enter another interval. To avoid idle session timeouts on cloud-based clients, set the interval to 200 seconds or less.
  10. From the Backup infrastructure list, select the a server group that will initiate connections with members of the Servers group.
  11. Optional: To edit the Tunnel port and Keep-alive interval options, as described in Step 9, above.
  12. Click Next.
  13. Optional: Edit the following advanced options:
    • Move the Encrypt traffic toggle key to the right to encrypt network traffic (HTTPS).
    • Select Encrypted, Authenticated, Regular, or Raw from the tunnel protocol list.
    • Select the Parallel data transfer streams for long distance networks (default value is 1, and maximum value is 8).
  14. Click Submit.
