Verify that your environment meets the requirements for protecting HPE Morpheus HVM VMs with Commvault.
Access Nodes
You can install the access node package when you configure backups for your HPE Morpheus HVM instances.
Install the access node package on the physical node of the HPE Morpheus HVM cluster. You can install the access node package on other nodes to improve performance.
The HPE Morpheus HVM physical node is recommended to have the following:
At least 60 GB free disk space
At least 4 GB RAM, excluding the operating system and running applications
If the HPE Morpheus HVM instances are hosted on local storage, then the access node package must be installed on all the nodes of the cluster.
Linux Instances
Guest tools must be installed on Linux instances.
