Commvault Edge Reference Architecture Technical Specifications
Commvault validated reference design documents deliver tested configurations with leading hardware vendors to provide validated designs, complemented by best practices and configurations which will accelerate ROI, and reduce complexity.
Validated design specifications for the following servers are available:
Components
Specifications
Vendor
Dell
HPE
Lenovo
Hardware Models
Dell R660xs
Dell R760
HPE DL320 Gen 11
HPE DL360 (Gen 10 or Gen 10+)
HPE DL380 Gen 10, Gen 10 Plus, or Gen 11
Lenovo SR630V3
Minimum CPU cores
16 or more cores, regardless of socket count (Intel Xeon 3rd gen Silver minimum)
Memory
64GB RAM, minimum
Boot Device
240GB or larger There must be a dedicated boot device with a Hardware RAID 1 configuration, preferably 2 x SSD/NVMe devices. Software RAID, such as VROC, are not supported.
Hardware RAID Controller
Dell H755
Dell H965i
HPE Smart Array P816i
HPE Smart Array P408i
HPE Smart Array E208i
HPE Broadcom MR216i
HPE Broadcom MR416i
Lenovo 5350-8i
NVMe/SSD Flash Device
960GB minimum cache size for up to 50TB usable ROBO capacity
1.6TB minimum cache size for 50-75TB ROBO capacity
3.2TB minimum cache sizefor 75-150TB ROBO capacity
Storage Pool Data
Up to 12 drives may be configured in a supported Hardware Model
Up to 20TB capacity per drive supported
Configure hardware RAID volumes for the data drives
Network
Broadcom 57414 Dual Port 10/25Gb SFP+ or SFP28 card
Broadcom 57504 Quad port 10/25Gb
Broadcom 57416 Dual port 10Gb Base-T card
Intel XL710 2-port 10G SFP+
Intel X710 Quad Port 10Gb SFP+
Intel XXV710 Dual Port 10/25Gb SFP28
Intel X520 Dual SFP+ 10 Gb NIC
Mellanox MCX4121A-ACUT Dual port 10/25Gb SFP28
Mellanox MCX512A-ACAT ConnectX-5 EN Adapter Card 10/25GbE
Fiber HBAs
Qlogic 2772 Dual port 32Gb Fiber HBA
Qlogic 2692 Dual port 16Gb Fiber HBA
Emulex LPE35002 Dual port 32Gb Fiber HBA
Emulex LPE31002 Dual port 16Gb Fiber HBA
