Commvault Edge Versions and Images
Commvault monitors and tests the updates available for the Commvault Edge on Linux server and if any updates affect the stability and security of the ROBO server, they will be released to customers on a monthly basis.
Verify the latest Commvault Edge versions to see if the Commvault Edge server in your environment need to be updated.
Important
Versions that are older than 3 months are outside of support and will be worked as best effort. It is recommended to regularly update your server to one of the latest 3 versions to ensure supportability. In certain scenarios, to install critical updates, Commvault may require you to update to the latest platform version to resolve any issues."
