Setting up the network is the first phase in deploying the Commvault Edge nodes. All the network related information is required during this phase.
Make sure to determine your network topology before setting up the network in your Commvault Edge node.
Network can be setup using one of the following configuration methods depending on the network topology for your environment:
Use one of the following configuration methods depending on the network topology for your environment:
