Adding OneDrive for Business Data Sources to a Project
You can add Microsoft OneDrive for Business data sources to a project. After a data source is crawled, the personally identifiable information (PII) (entities) defined in the data classification plan associated with the project is discovered in the data source.
  1. From the navigation pane, go to Activate.
    The Activate page appears.
  2. Under Data Governance, click Sensitive data governance.
    The Sensitive data governance page appears.
  3. Under Quick start, click OneDrive.
    The Quick start page appears.
  4. On the Project tab, under Select project, from the Project list, select a project.
  5. Click Next.
    The Add OneDrive page appears.
  6. On the Select OneDrive tab, select the check box next to the drive you want to add.
    If you do not see the server that you want to analyze, in the upper-right corner of the page, click Refresh inventory.
  7. Click Next.
  8. In Display name, enter a name for the server.
  9. From the Country name list, select the country where the server is located.
  10. Choose the data to analyze:
    • To analyze all backed up data on the drive, click Analyze from backup.
    • To analyze all of the data for a subclient whether the data is backed up or not, do the following:
      1. Click Analyze from source.
      2. Click Browse.
        The Select a path dialog box appears.
      3. Click the check box next to the subclient that you want to add.
      4. Click Save.
  11. Click Finish.
    The drive appears in the Data sources table.
After you add the data source to the project, a data collection job runs to crawl and to analyze the data in the data source. If at a later time you want to update the data collected from the data source, you can run a data collection job from the data source details page. For more information, see Collecting Data from Data Sources.
Creating a Data Classification Plan
