You can change the following settings when recalling the index automatically from an archive cloud storage:
Enable recall from an archive cloud storage managed by a life cycle rule
Change the default recall method for automatic recalls when restoring data from Glacier to S3
Change the default recall method for automatic recalls on Azure libraries
Set the retention days for the restored data on AWS cloud libraries
To the CommServe computer, add the additional settings as shown in the following table.
For instructions about adding an additional setting from the CommCell Console, see Adding an Additional Settings from the CommCell Console.
Additional setting
Category
Type
Value
Default value
CommServDB.GxGlobalParam
Boolean
true
False
Integer
Supported values are 0 (Standard), 1 (Expedited), 2 (Bulk).
0
Integer
Supported values are 0 (Standard), 1 (High Priority).
0
Integer
Number of days to retain restored data from AWS cloud.
7
