Install Index Store and Index Gateway for File Storage Optimization
The Index Server performs the content indexing and data analysis operations for File Storage Optimization. The Index Gateway facilitates communication between the File Storage Optimization components. To configure these entities, you must install the Index Store package and the Index Gateway package on a computer in your environment.
Complete this procedure as part of the initial configuration of File Storage Optimization. For more information, see Getting Started.
  • Review the system requirements for File Storage Optimization.
  • For test environments, you can install the software on the same server with the Commvault package. For production, install the software on a separate, dedicated computer.
  1. On the computer where you want to install the package, download the Commvault enterprise media kit installer from the Cloud Services website, and then run the installer.
  2. Follow the prompts in the installer:
    1. In the Choose the Installation Type page, click Install packages on this computer, and then click Next.
    2. If you are installing the software on the same computer as the Commvault package, on the Install Option page, click Advanced selection, and then click Next.
    3. In the Select Packages page, under Server, select the Index Store package, and then click Next.
      The Index Gateway package is automatically selected when you select the Index Store package.
    4. In the Installation Path page, select a path, and then click Next.
    5. In the Data Directory Path page, select a path, and then click Next.
    6. In the Installation Summary page, review the information.
    7. Click Next to begin the installation.
    After installation of the packages is complete, use the server to create an Index Server in the File Storage Optimization guided setup.
Return to Getting Started and complete the setup.
