Setting Up a One-Way Forwarding Connection Through a Network Gateway Using a Predefined Network Topology
If you are setting up group-to-group network connectivity through a network gateway (where the network gateway establishes a connection to internal clients), consider using a one-way forwarding connection through a network gateway using a predefined network topology. You can set up such a connection for laptops and servers.
