Commvault Plug-in for SQL Management Studio
Applies to: SQL 2012 and more recent versions. The Commvault Plug-in on the SQL Management Studio is not supported for SQL Server on Linux.
You can use Commvault Plug-in to perform Commvault backup and restore operations in the SQL Management Studio. After you configure the Commvault Plug-in on the SQL Management Studio, the options to back up and restore are made available in the SQL Management Studio.
Commvault Plug-in for SQL Management Studio is part of the SQL agent package. To perform configuration, install the SQL agent on the server where SQL Management Studio will be used.
Commvault does not support configuring the Commvault Plug-in if SQL Management Studio is installed on a Windows 32-bit operating system.
You cannot use the Commvault Plug-in on the client that has the CommServe installed.
Enabling the Commvault Plug-in on SQL Management Studio
Running Backup Operations from SQL Management Studio
Restoring the Latest Backup Cycle from SQL Management Studio
Restoring the Backed Up Databases from SQL Management Studio
