Configuring HPE 3PAR StoreServ / Primera / HPE Alletra 9000 Series / HPE GreenLake for Block Storage Array Using Array Management
For IntelliSnap backups from the Commvault software using either the HPE 3PAR StoreServ, the HPE Primera, the HPE Alletra 9000 Series, or the HPE GreenLake for Block storage array, add the HPE 3PAR StoreServ storage array and its configuration information to the CommServe database.
For the Name box in the procedure below, you might need to calculate the storage array name, depending on the application that you are using to manage the storage array.
If you are using the StoreServ Management Console (SSMC) to manage your array or directly accessing array using service console, then you do not need to calculate the array name. In the Name box, enter the World Wide Name (WWN) of the storage system.
If you are using the old management console (InForm Management Console), then for the Name box, calculate the storage array name.
For the credentials below, the user type must be local user with edit and super level. The domain user is not supported.
  1. On the ribbon in the CommCell Console, click the Storage tab, and then click Array Management.
    The Array Management dialog box appears.
  2. Click Add.
    The Array Properties dialog box appears.
  3. On the General tab, specify the following information:
    1. From the Snap Vendor list, select HPE 3PAR StoreServ.
    2. In the Name box, enter the WWN identifier of the storage array in upper case.
    3. In the Control Host box, enter the management IP address of the array.
    4. In the Credentials area, click Change.
      The Enter the User Name and Password dialog box appears.
    5. Type the credentials of a user who has the Super User permission or the Edit User permission, and then click OK.
  4. To configure additional MediaAgents to perform operations on the storage array, on the Array Access Nodes tab, select configuration options.
    For more information, see Configuring Array Access Nodes.
  5. On the Snap Configuration tab, set the snapshot configuration options that you need. See Snapshot Configuration Properties for the HP 3PAR Storage Array.
