Configuring the HPE EVA Array Using Array Management
For IntelliSnap backups from Commvault software, add the HPE EVA storage array and its configuration information to the CommServe database.
Ensure that the client and proxy computers are configured and have access to the array.
  1. On the ribbon in the CommCell Console, click the Storage tab, and then click Array Management.
    The Array Management dialog box appears.
  2. Click Add.
    The Array Properties dialog box appears.
  3. On the General tab, specify the following information:
    1. From the Snap Vendor list, select HPE EVA.
    2. In the Name box, enter the World Wide Name (WWN) of the array node, which is the serial number for the HPE EVA storage device. Type the array name without dashes (for example, 50014380025DEB70).
    3. In the Control Host box, enter the name of the management server of the array.
      Note: Enter the server name only, not the fully qualified domain name (FQDN) or the TCP/IP address.
    4. In the Credentials area, click Change.
      The Enter the User Name and Password dialog box appears.
    5. Type the credentials of a user who is member of HP Storage Admin group, and then click OK.
  4. To configure additional MediaAgents to perform operations on the storage array, click the Array Access Nodes tab, and then select configuration options.
    For more information, see Configuring Array Access Nodes.
  5. On the Snap Configuration tab, configure the snapshot configuration properties for your environment or use the default values.
    For more information, see Snap Configuration.
