Configuring Retention Settings for Deleted Files in Edge Drive
You can set retention rules for user deleted files in Edge Drive from the CommCell Console.
By default, files that are deleted from Edge Drive are retained in the Edge Drive trash location for 30 days.
Before you can begin this procedure, you must have created an Edge Drive client. See Creating and Configuring an Edge Drive Client.
  1. In the CommCell Browser, click Policies > Subclient Policies.
  2. Click the subclient policy for the Edge Drive client that you want to use.
    Edge Drive subclient policies have the following naming convention: <Edge Drive client name> Subclient Policy
  3. Right-click Default subclient and then click Properties.
  4. On the Retention tab, in the Files deleted by user group, select the retention period for the deleted files in Edge Drive as follows:◦
    • To define a specific retention period, click Retention period (in days) and type or select the number of days you want to retain the files in the Edge Drive Trash location.
    • To define infinite retention period, click Indefinite Retention.
  5. Click OK to apply the retention settings to the associated Edge Drive client.
