By default, the Web Console displays all data from the default and non-default subclients in the default backupset on your client computer. You can disable data browse from non-default subclients.
On your Web Console computer, add the additional setting that applies to your agent:
Property
Value
Name
For non-default file system subclients: useFsBackupsetLevelBrowse
For non-default SharePoint subclients: usespBackupsetLevelBrowse
Category
WebConsole
Type
Boolean
Value
Select one of the following values:
False - to disable data browse from non-default subclients in the defaultBackupSet.
True - to enable data browse from all subclients in the defaultBackupSet.
Restart the Tomcat services on the Web Console computer.
