This topic provides information related to hardware maintenance.
Media Retirement
Use this dialog box to view or modify the retirement threshold values for tape media.
Media Retirement Thresholds
Media Type
Displays the media type to which the thresholds apply.
No. of Read, Write Errors
Displays the number of read, write errors that are allowed while writing to or reading from media before the media is marked as Bad.
No. of Years
Displays the length of time that the media can remain in use before it is marked as Deprecated.
No. of Reuses
Displays the number of times that the media can be recycled before it is marked as Deprecated.
No. of Media Label Errors
Displays the number of errors that are allowed while writing the media label before the media is marked as Bad.
Edit
Click to modify the maintenance thresholds for the selected media type.
Drive Cleaning
Use this dialog box to view or modify the threshold values for cleaning drives in a tape library.
Drive Cleaning Thresholds
Drive Type
Displays the drive type to which the thresholds apply.
No. of Read, Write Errors (Since Cleanup)
Displays the number of read, write errors that a drive can encounter before it needs to be cleaned or fixed.
No. of Mount, Unmount Errors (Since Cleanup)
Displays the number of mount, unmount errors that a drive can encounter before it needs to be cleaned or fixed.
Time (Hours) Used (Since Cleanup)
Displays the total number of hours that a drive can be used before it needs to be cleaned.
Cleaning Duration (Seconds)
Displays the total amount of time (in seconds) that the cleaning media must be run on the drive during a drive clean operation.
Edit
Click to modify the cleaning thresholds for the selected drive type.
Drive Maintenance
Use this dialog box to view or modify the drive maintenance threshold values for a tape library.
Drive Maintenance Thresholds
Drive Type
No. of Read Write Errors (Lifetime)
Displays the number of read, write errors that a drive can encounter before it is marked offline.
No. of Mount Unmount Errors (Lifetime)
Displays the number of mount, unmount errors that a drive can encounter before it is marked offline.
Time (Hours) Used (Lifetime)
Displays the total number of hours a drive can be used before it is marked offline.
Edit
Click to modify the drive maintenance thresholds for the selected drive type.
Library Maintenance
Use this dialog box to view or modify the retirement threshold values for a tape library.
Library Maintenance Thresholds
Library Type
Displays the library type to which the thresholds apply.
Connectivity, Status Check Errors Since Fix
Displays the number of connectivity, status errors that a library can encounter before it is marked as Broken.
Mount, Unmount Errors Since Fix
Displays the number of mount, unmount errors that a library can encounter before it is marked as Broken.
Edit
Click to modify the maintenance thresholds for the selected library type.
SCSI Error Translator
Use the following parameters to translate SCSI error messages returned from a library.
The SCSI error message is a five digit hexadecimal code, such as 0x09 83h 02h. If the 0x0 and h are dropped the error message consists of the following three parts:
The first part (which is 9 in this example) is the sense key (SC) which is a hexadecimal number in the following range: A to F or 0 to 9.
The second part (which is 83 in this example) is the Additional Sense Code (ASC) and the third part (which is 02 in this example) is the Additional Sense Code Qualifier (ASCQ). Together, this provides detailed information about the error.
To translate the error code returned by the library, enter the SC, ASC and ASCQ and then click OK. The error message is translated and displayed in the SENSE CODE or ASC & ASCQ box.
Sense Codes
SC
Specifies the sense code.
ASC
Specifies the additional Sense Code (ASC)
ASCQ
Specifies the additional Sense Code Qualifier (ASCQ)
Look Up
Click to display the description of the error code.
Error Description
SENSE CODE
Displays the error message.
ASC & ASCQ
Win Error Translator
Use the following parameters to translate Windows error messages returned by the operating system.
To translate the error code , enter the error code in the Error Code box and then click Look Up. The error message is displayed in the Error Description box.
Error Code
Specifies the error code.
Look Up
Error Description
Displays the description for the error.
