You can log on to the CommServe using your smart card (also called a common access card (CAC)). After you insert the card into the laptop and type your PIN, your Windows log on credentials are used to log on to the CommCell Console or the Web Console. If you log on to Compliance Search, you can choose to log on using any account on the smart card.
Requirements
You must configure Kerberos constrained delegation in your environment though either of the following:
software
a device
You must enable single sign on (SSO) on your Active Directory domain.
