Between backups, the data may undergo modifications. If you want to recover old versions of the backup data, use the following steps to restore or download the previous backup versions of a file.
From the Web Console, click My Data.
Click the Computers tab.
Under My Computers, click Restore for the computer that contains the file that you want to restore.
From the Restore Files page, navigate to the folder where the file resides.
Click the down-arrow next to the file and then click View Versions.
All versions of the file are displayed. For example, if the file has two version, it will be listed as file (1) and file (2).
