You can run remote installations from the command line by using the .xml file that was created when you saved the installation in a script. The .xml file contains the selections you made during the installation.
Saving the remote installation in a script is useful in the following scenarios:
You want to run the installation at a later time.
You want to save your installation selections if you must reinstall the software due to a hardware failure.
You might have a batch script with a set of administrative tasks, and you want to define the installation task in the batch script (by calling the .xml).
You must have saved the installation as a script. For instructions, see Installing Commvault Remotely Using the CommCell Console.
Log on to the computer where you saved the script.
At the command line, go to the Installation_Directory_Path/Base directory.
To log onto the CommServe database, run the following command:
qlogin -cs commserve_host_name -u user_name -
To run the script (.xml file), enter the following command:
qoperation execute -af Path_to_XML_File -
To log off of the CommServe database, enter the following command:
qlogout
