Sensitive Data Governance: System Requirements and Hardware Specifications
Verify that your environment meets the system requirements for Sensitive Data Governance.
Commvault Packages
To use Risk Analysis for Sensitive Data Governance, install the following packages on computer(s). You will use the computer with the packages to create an Index Server in the Sensitive Data Governance guided setup.
  • Index Store
  • Content Analyzer
  • Web Server
Operating System
The computer that you install the required Commvault packages on must use one of the following operating systems.
Windows
  • Microsoft Windows Server 2022 Editions
  • Microsoft Windows Server 2019 Editions
  • Microsoft Windows Server 2016 x64 Editions
  • Microsoft Windows Server 2012 R2 x64 Editions
  • Microsoft Windows Server 2012 x64 Edition
Linux
  • Red Hat Enterprise Linux/CentOS 7.3 and above
  • Rocky Linux 8.x or 9.x
Hardware Specifications for the Index Server
Use the following guidelines to select the appropriate hardware for your Index Server.
Considerations
  • Size up to the larger specification if either of the following cases applies to you:
    • Your environment is between two sizes
    • You are using one Index Server for both Exchange data sources and Exchange backups
  • If you are using one Index Server for both files and email messages, use the size that matches the larger source. For example, if you have 40 TB of file source data and 15 TB of email source data, use the specification for a medium-sized server.
  • The following options affect the performance of the Index Server:
    • Custom entities that include multiple regular expressions
    • Data classification plans that include the optical character recognition (OCR) option or the pre-generated previews option
Specifications for File Data and Email Messages
Component
Medium
Small
File source data size per node
160 TB
80 TB
File objects per node (an estimate based on an average file size of 2 MB and on the assumption that 50 percent of documents are eligible for content indexing and there is more than one version of the file)
40 million
20 million
Email source application size
15 TB
5 TB
Email objects per node (an estimate based on an average message size of 100 KB. Messages with attachments are considered a single object)
150 million
50 million
CPU
16 cores
8 cores
RAM
32 GB
16 GB
Index disk space
(SSD class disk recommended)
6 TB
3 TB
If the size of backed up data exceeds the prescribed limits, then you must configure dedicated index servers for email and file data based on the specifications as mentioned in the Specifications for Dedicated Servers for File Data and Specifications for Dedicated Servers for Email Messages sections.
Component
Large
Medium
Small
Source data size per node
320 TB
160 TB
80 TB
Objects per node (estimated based on an average file size of 2 MB and on the assumption that 50 percent of documents are eligible for content indexing and there is more than one version of the file)
80 million
40 million
20 million
Objects per node (estimated for live scan based on an average file size of 2MB)
160 million
80 million
40 million
CPU or vCPU
32 cores
16 cores
8 cores
RAM
64 GB
32 GB
16 GB
Index disk space
12 TB
6 TB
3 TB
Component
Large
Medium
Small
Source application size
25 TB
15 TB
5 TB
Objects per node (an estimate based on an average message size of 100 KB. Messages with attachments are considered a single object)
250 million
150 million
50 million
Number of mailboxes (based on an average mailbox size of 5 GB, and an average of 50,000 messages per mailbox)
5000
2000
400
CPU
16 cores
16 cores
8 cores
RAM
64 GB
32 GB
16 GB
Index disk space
10 TB
6 TB
2 TB
Hardware Specifications for the Content Analyzer
Content analyzer computers detect personally identifiable information (PII) in the data. Some Risk Analysis environments require dedicated content analyzer computers.
Review the following use cases to determine if you need dedicated content analyzer computers:
  • You need to identify machine learning-based entities. For example, Address, Contextual Date, Location, Money, Organization, Person, and Time are entities that are identified by using machine learning. For a complete list of built-in entities, see Personally Identifiable Information.
  • You want to configure parallel processing. You can add multiple content analyzer computers, and then create a separate data classification plan for each content analyzer.
Before you install the Content Analyzer package, use the following guidelines to select the appropriate hardware for your content analyzer computers.
Use case
CPU
RAM
Disk space
Machine learning-based entities
32 cores
64 GB
2 TB
Parallel processing
16 cores
32 GB
1 TB
To distribute the processing load, you can install the Content Analyzer package on multiple computers.
